Whats up guys. My flame retardant NOOB suit is buttoned on. I am having troubles finding a S13 DE long block for my NA build. Can I use and S13DET? Other than the turbo setup, couple sensors and obviously a different compression are they pretty much the same?
Have been searching this since yesterday on a few different forums and everytime I think I am close i end up reading about a Sentra swap or something.
Dude … you really need to re-word things. The term “DE” just means Dual Overhead Cams. If your looking for a long block KA24DE , there are tons. The Sentra on the other hand is an SR20DE ( if im correct ) and its a FWD engine, meaning it wont work for any RWD setup, ( unless you do all the conversion work, but there is no point ). KA’s that are turbo charged ( custom made ) use the same sensors i belive. But yea … your post was confussing and this was the only answer i had at the moment.
Hmm aparently I cannot edit the original for some reason. Sorry for the confusion. I am trying to source an S13 SR20de for an NA build. I cannot find one. Can i use an S13 SR20det in its place? What are the major differences other than what i listed above.
Nothing against the KA really. After a few weeks of trolling on forums I have found more things that favour the SR for what i would like to try personally…especially if I get brave enough for a VE head swap.
Stock they are about the same. Definitely more of a market for doing the SR build. Most easily accesible aftermarket parts for a KA are turbo spec. I.E. Cams, pistons, etc…
and Y the hell would you want to UN turbo a SR?? You would have the low compression so it would be slugish all the time. and yea… that would just be really dumb… if you want SR go SR20DET! or u want NA go with the lil bit of torque from the KA
Baically are the gasket sets interchangable? Front cover? Oil pumps are different I believe. Are the internals essentially the same other than rod material and compression? Is the DET Coil while the DE has a distributor? Stuff like that
Pretty sure you can get a DE for cheap too if imported. If you wanna be really baller, grab a DE from an S15, there was definitely a high output version of it, I believe near the 200hp mark.
just do the srde swap im pretty sure everything but the hea you can take off of a sentra with a sr20de the head just dont swap becuase of the anti freeze ports
hmmm just did a quick search. Appears were both right. Only s14 and s15 silvias had that 160hp your talking about. The rest in previous years were less powerful, as low as 125hp actually.
