So, I was driving to work one day, and the car started puttering around 3-4k, so i took it out of gear and it was fine. however everytime I give it gas it would die or drop the idle. it smells like gas. I think it is the fuel pump? Does anyone know what the problem is or have any idea what it is?
i was driving hard and my hot pipe popped off and the motor was not getting the correct boost that is on my sr20 application and that same problem happened… what motor do you have?
Low pressure? bad fuel pump or regulator perhaps or catalytic converter clogged. Have you checked injectors? Rings may need to be replaced.
Well at the very least you should be able to check if the gas tank hoses are ripped without much trouble.
Is it auto or manual? Has it been over heating? Are you sure it smells like gasoline and not burnt tranny fluid? Does it stall in every gear? Do you not feel much power from revving up in every gear or just a certain gear? also, shift cable/linkage not fully in can mean slippage during acceleration.
