Car not right this morning
I hopped in my car to drive to work this morning and started it up. I put the car in reverse and went about 30 feet in reverse and the car started sounding like my brakes were scraping with kind of a grinding sound. I still had about 30 feet left to go in reverse…pulling out of between townhomes. I stopped the car, got my 4 way out and checked all lugnuts, all were fine. I backed it up all the way and it did it the entire time. Put it in drive and did the same thing for about 20 feet then stopped making the noise. Plus this entire time, it felt as though the car was needing me to give it more gas to move. After the 20 feet in drive, it stopped till I got 40 miles to work then I pulled in the Dunkin Donuts. I was pulling into a parking spot and I had to go over a speed bump and my passenger rear tire was resting on the speed bump and the car did the same thing right when I was coming to a stop in the spot. I went in got my coffee and put the car in reverse. The car felt again like the E-brake was on and really didn’t want to move. I put the car in drive and took off. It did it again for about 20-30 feet in drive then stopped. I got to work, looked under the car and saw nothing rubbing or caught up anywhere.
What could this be? Weird it only does it everyonce in awhile.
E brake stuck maybe?
[QUOTE=PewterSS][/QUOTE]
Thats what I was thinking but it did it after driving for 40 miles and being fine then did it again when parking. I called up a shop I have had work done at before and he said it might be a broke caliper bolt or a loose one. Guess I will be checking them in my work parking lot today
I took the tires off the car and took a look at all the calipers. The two on the driverside were a little loose and can move slightly when I shake them. I do not have any tools here at work so I guess it will have to wait till later. I also took the car out for a drive and it didn’t do it anymore when I was out. I also felt the wheels after about 10 minutes and all felt like the same temp. Well, hopefully it was just some random thing that won’t happen again. Guess I will find out soon enough
thats good
