car not starting.
Legend:
_ = sitting
  • = started
    X = attempted to start
Diagram: ( _ _+ _ _ _ X)
so i let the car sit for 2 days after not driving it, i got in and started the engine and let it run for like 10 mins and pulled in the drive way. i then tried to start the car after letting the car sit for 3 more days, the car wouldn’t start i figure the batt was dead, tried to jump it and the lights (clock + display mby radio 2 i don’t know) flashed on and went right off, engine doesn’t make any noise when trying to turn it over nothing… let the car sit for like 2 mins and tried again, nothing…doesn’t try to turn over, no sound just nothingness… foreveralone.jpg
should i just try and jump it again and let the car sit for like 5-10 mins to charge the other batt? i might just be paranoid now about everything cuz everything decided to break all at once (which is the reason the car was sitting)
oh also this batt in the 240 is like brand new from Canadian Tire (less then 2 months od)
does it start when you jump it with another car?
i would start by checking main ground wire from battery for corrosion/bad connection
probably alternator
