Couldn’t figure out how to get different weight options for the various motor configurations available. Ex. it only listed the weight of a 4 cyl S-10 and I would bet it doesn’t weigh the same as the v6.
Did I pass it up?
same here that sucks. i’m looking for the weight of a 87 monte LS v8
i’m not seeing the weights stuff…
i use autotrader most of the time… go to model info, and then when your car comes up, look at the technical specs page
http://www.autotrader.com/research/model_info/index.jsp?restype=used
If you want the true weight of your car we have Scales at Speed Nation.
can u do each wheel?
2739lb?
yikes.
+1… good to know for balancing a car for handles on a road track or even setin up suspension at the strip
2108, not to shabby, but mine only has the driver seat, no pass or back so it’s probably closer to 2050
a lil late but yes he has 4 scales!
3200lbs… umm wow
grand national = 3349 lbs:weak:
Curb Weight: 4057 lbs. for the crown vic
2758
2326 for my RX-7 but its a little less than that now. also lists my car as haveing 2 cyls ha
2661 lbs = stock curb weight
suzuki stock=1870 lbs
'01 Grand Cherokee Limited = 4067 lbs.
With 4.7L V8 = 4206 lbs. WTF
01 ram says 5283 lbs, probably more with my stuff.
'99 Passat 3122 lbs + 250
…doesn’t help me in STS
