I keep telling you, just add the “ski” and you will be all set. lol.
actually i believe i won
hahahahahahh ![]()
who would have thought they actually tow in tow away zones.
Ughh
Turns out i actually 3 holes (cracks) in the manifold the whole summer, which would explain the car’s wierd behavior. Chuck (Firehawk853) tuned it best he could, and even said it seemed like it had a vaccum leak months ago, but we couldnt find it. Then the other night, i guess it just decided to let go and thats when the HUGE crack happened. Turns out, the FAST manifolds are easy to crack if you tighten them down too hard, which is exactaly what the former owner did. The car runs a whole lot better now and has excellent street manners, eventhough its pig rich and need a re tune BADLY. I can only imagine it will get better. Thanks to Psycopjv and JnJ for their help.
:tup:
are you serious? air pocket in the cooling system? you were nowhere near the problem. a cracked manifold is leaking in unmetered air into the engine causing sensors to compensate for something they can’t fix. This had nothing to do with the cooling system. An air pocket in the cooling system will cause a “hot spot” which can make the guage go nuts and affect the idle slightly. not to the point of 4,000 rpms though.
Could this mean theres a good possibility you’ll be running like 11.6-11.7 if you went to nyi again with a retune?
with a driver mod maybe
jk man ![]()
glad to see it worked out for ya
don’t worry he’s got me to do it…
Yup cant drive my car, thats why i can cut 1.7’s at lancaster right? NYI can lick ma nutz
ill powershift that bitch into the mid 11s…
hey it’s not my tranny :gotme:
Go back and run an 11 before the snky.
im pretty sure my first statement said “vacuum leak”
then i went into a couple other things.
but either way glad u found your problem. gl with the re-tune
with a re-tune it will be better than ever.
if only there was a 1/4 mile close that preps their track, nyirp last friday was a joke
:wiggle:
you have 1 new text message
