anyone have some good ways to clean the EGR out? mine keeps trippin the SES light, i took it off and cleaned it up with some carb and choke cleaner, worked for a week, then came back on last night
will seafoam do anything with it? I know it is suppose to take carbon off… but im not sure if it has to be burned, or what?
Did you consider deleting it, or would you be screwed for your emissions inspection?
I know it’s not really a performance enhancer, but for me it was cheaper to delete it than replace the EGR valve. However, supposedly the EGR system helps keep knock under control at partial throttle by keeping the combustion chamber cooler. This is for a stock setup though, not for a bigger cam. Just a few things to consider!
