Cleaning the inside of an old tank
Im working on my tank lately and have to tackle the rust on the inside of the tank. I called a radiator shop and they quoted me $85-95 to clean the inside without putting any coating on. Me being the DIYer that I am, Id rather try to do this myself as long as I can do it for uner $100. I figure if I can buy all the materials Ill need to do this tank for under the cost of paying someone, then ill OWN the materials needed to do other tanks. Trying to save some money in the long run.
Ive read about electrolysis and it seems like thats the way to go. Ive been looking on Craigslist for a trickle charger but in my reading ive seen that the type of charger you use is a very big factor. With that said, can anyone give me some advice or pointers as too what exactly I need to get to do this? Plan is to get a big rubbermaid container that I can put the whole tank in and do it to the whole tank. There is some rust on the underside of the tank as well so I figure I can kill two birds with one stone. After rust is removed, Im going to coat the inside with some Por-15 if I can find it or some other liquid liner. The underside of the tank will also get Por-15 or else some bed liner.
Thanks
Gas tank? Radiator end tanks? Fish tank? Oil tank?
If it’s an oil tank just turn it into a meat smoker.
LOL note that this is in the bikes section so I would assume that it is the fuel tank on his bike. I am probably wrong though since there is no information aside from TANK in the post. I hope that it is a panzer.
Honestly this is what I was picturing the entire original post read
http://www.ubergizmo.com/photos/2007/9/paintball-tank.jpg
If that’s the case, then Kerosene + tumbling stones + shake it like a salt shaker.
Oh, and you can get POR-15 at K&S, but I personally wouldn’t put anything on the inside of the tank.
WOW. I didnt think I needed to specify GAS tank when posting the word “tank” in the “bike” section.
What are tumbling stones and where do you get them?
Why wouldnt you put anything inside the tank to seal it? If you dont seal it, wont it rust rapidly again?
If the inside of your tank is rotting it’s time for a new tank. Usually you only clean out the inside of a gas tank to get rid of gummed up gas.
More details. Why are you “working on the tank”? What bike is this? Year/make/model?
The gas will eventually disintigrate the por 15.
not a good idea
I would not use por15 that would just be dumb. The best stuff from what I have seen is called Red-Kote and can be found at Napa
http://www.damonq.com/images/Red-Kote2b.jpg
electrolysis
http://www.youtube.com/results?search_query=gas+tank+electrolysis&search_type=&aq=0&oq=gas+tank+el
http://www.google.com/#hl=en&source=hp&q=motorcycle+gas+tank+electrolysis&aq=1m&aqi=g1g-m1&oq=gas+tank+ele&fp=6b22d27f49a5e7dd
Im going to go pick up a shitty battery charger today and try this out.
For reference, bike in question is in my build thread found here:
http://www.nyspeed.com/forums/showthread.php?t=75824
