just went out andplayed with shit, everything is now coated in black iron instead of rust … except where there wasnt a clear line of sight from the positive electrode to the rust
to fix that, i cut up some small pop bottles to use as spacers top and bottom and put the + electrode INSIDE the pipe i need to finish cleaning … in a while ill go make sure the plastic is holding up well
tomorrow ill swap the setup to the other pipe i have to finish inside, and ill be all set
takes 3 hours to totaly clean a piece of well rusted exhaust pipe
Hmmm…we have a spare room in the apartment. And a metric fuck-ton of parts. Maybe it’s time for a copycat project.
As for a computer power supply, I believe it’s the green pin shorted to the black pin that will turn it on. There are a million sources online that will tell you how to jumper one to run. That’s probably what I’d use to power a tank, if I were to make one.
dont do it, the process forms bubbles on the + electrodes and on the parts themselves … the bubbles are hydrogen and oxygen … fill a room with that stuff and you get an explosion that will level the building
