installed coilovers today, doesn’t look too bad, not too low where i’d be scraping the ground. Anyways, when i turn the wheel i hear a clicking noise, the noise is more of spring being flicked. Anyone know what this noise is??? and is there any potential damage that i could do to the car?
Check to make sure the little collars used to adjust height are tight…they might be loose and the spring is turning. best thing to do is have a friend turn the wheel while you look and see if you can spot a noise.
Inspect the bearing or pillow mount at the top as well.
