Who buys stock clutches?
Who buys 1,000 times the clutch they need?
You can’t call up Eurodrive and have them make you a clutch, with pressure plate, TOB etc and expect to get it for that price.
In all honesty, beyond the material used, a Eurodrive (or similar) performance clutch shouldn’t cost any more than an OEM unit.
Unsprung clutches are better suited to drag. You know “range of engagement” - ie how hard and how quickly the clutch grabs - is controlled by springs.
Without them, your clutch becomes an on/off switch. No slip.
Every time you move the car from a dead stop you have to “pop” the clutch.
Try driving your car right now by only slamming your foot on the clutch and off. Try starting up from a stop light without slipping the clutch.
That’s what day to day driving will be.
It’s also unnecssarily hard on driveline components.
Beyond that, the springs absorb vibrations. Not only is an unsprung clutch noisier, it also has a very short life expectancy.
The fewer cylinders you have, and the more boost you push, the more vibrations.
Any time you run too much clutch for your setup, you’re putting your tranny through hell and paying out a lot more than you need to.
The more aggressively a clutch is designed, the more compromise in driving quality (chatter, short life, poor engagement) is made.
A “puck” or “button” clutch doesn’t necessarily have to have less disk, or be star-shaped.
Because of the high clamping force of the material used in race clutches, less material is needed. Less material means less weight, and a lighter clutch will rob you of less power.
Cheap-o companies build clutches onto existing OEM-style discs. They just change the material. When you make 100,000 different applications for OEMs, spending millions on redesigning a clutch center is just not worth it.
They take a core, and rivet new material to it.
