hey everyone. i tried to start my car today so i could warm it up and get it ready for tomorrow’s meet… i rolled back out of my driveway, then tried to put it into reverse… and it didn’t go! so then i just pushed the shifter a bit harder into reverse and it grinded :(. something seemed terribly wrong at that point… i then tried to go into first and then it wouldnt go at all… same thing with all the other gears, so i just sat there and turned it off… thought my shifter might be sticky, but it worked with the engine off, so i am assuming it is my clutch.
anyways, anyone have a remedy for this? my car is parked outside at all times and garage storing is not an option for me (at my house anyways). thanks for all information in advance.
You could try bleeding the clutchline. There might be a small air bubble or water trapped. Also check if your master and slave cylinders are in good condition
Bleeding is a little tedious with the damper assembly. I’d recommend chucking the sucker out if you have the opportunity to do so.
as far as last night goes, i let it warm up for 10 minutes sitting there after i couldnt shift, so i dont think that helped much. i also tried what pavel said, but even if i can drive in first i cant get into second, and its a bitch to get out of gear too.
let me try to give you a more detailed explanation of the problem…
clutch pedal moves in and out fine. if i start it in gear with the clutch pedal down, it acts normal, when i let up clutch, it stalls. i would assume this is fairly normal behaviour. but when i start car out of gear, i cannot get it into gear, with clutch depressed. if i really force it, it grinds like heck. so right now, i’m not quite sure of what to do, but i hope it was just screwy cuz of the cold weather last night, and i hope it shifts fine today… [-o<.
how long do you guys usually let it warm up for? it has been sitting for 15 minutes and i still cannot shift… can anyone pinpoint the problem? btw forgot to mention, but it is an 91 s13… but everyone probably assumed this because i dont think s14s would do this!
