I just went to adjust my clutch pedal and i noticed clutch fluid all inside my car and on the pedal, its leaking where the push pin goes into the master i believe, now how would i go about fixing this? new master cylinder?
I’d say new master, and you might as well check out the slave too. Just in case you need to do them both. And you might as well go ahead and do thishttp://www.nicoclub.com/articles.php?id=251959 too, because trying to bleed the system afterwards is a pain.
