all i can tell is the springbasket has some burn stains so i would assume the flywheel does too, since assuming is bad i suggest you look for cracks on the flywheel and if there is any replace it with another one you can find on here for cheap, dont buy a new flywheel its a waste of money unless its aftermarket, and use soemthing to measure the thickness of the clutch disk and compare it to spec, call nissan to find spec if you need to, good luck…
you can save money by having the p-plate and flywheel resurfaced, as well you can get the disc re-done as well.
Not sure where you can get it done… I had mine done a while ago, but my memory isn’t vey good. But I do remember that it was far cheaper than buying new parts.
OK!
Thanks for the help guys. I am going to get a new clutch kit.
Now, about the flywheel… as far as I can tell it is just surface rust from sitting for a while thats all. I took an air hose to it just before the pics to remove the dust.
Any idea how much it would cost to have it resurfaced?
Or should I just sand off the surface rust and use brake cleaner on the flywheel?
resurfacing will usually cost you between 70 and 90 bucks. It is highly recomended. that surface has been burned pretty good. check it closely (very closely) for tiny little hairline cracks. If you see cracks, just replace it too.
