it turns over but it can’t idle, i have to blip the gas a bit to raise the idle and than slowly bring it back down again. this only happens when its cold and the car is not warm.
could be a multitude of problems, ur gas lines may be freezing , ur oil could be tooo thick , ive had that before with the same problem, if not ur idle up valve/coldstart/iac whatever u want to call it is malfunctioning , also could be your temp sensor
hmm…i don’t think its the gas line, cause it can start, but just stalls out immediately, it tries to idle but won’t, so i have to feather the throttle so it does go up and than ease it back down again and its fine.
