I know this is a long read, but please try to find the time to try and help me out. thanks.
I just picked up a new 180sx and i’m trying to get it running like a dream. I don’t have goals of high power right now, just the best milage and daily drivability i can get out of it. Has SR20det, intake and cat-back exhaust, automatic(for now) and 110,000KM’s.
When i first got it it drove like a dream for first 800km’s, very smooth power delivery and 30+MPG. Then it started over pressurizing the fuel tank and leaking a little fuel. As a temporary fix i tried another fuel cap and when that didn’t work i drilled a tiny hole in the cap to vent excess pressure.
Then over the next 1000KM’s the turbo came loose and blew the manifold to turbo gasket. I have it tightened up now but still leaks some exhaust. While doing this i removed the EGR valve and piping, and plugged the vacuum line.
Then it started leaking a little fuel from the line connecting the fuel filter, so I replaced the fuel filter and connecting lines. I also noticed some of the vacuum lines are a little dry and showing light cracking, so I plan on replacing those too.
Then i noticed a few tiny drops of oil coming out of the back end every once in awhile, and found the front of the diff where the driveshaft connects has some oil leaking out. Just a tiny bit, not a huge problem right now.
Now, since all these things have happened, I now have very slow spool up, low power until above 4000RPM, and my millage has been cut in half, i’m now getting only 16MPG. And I’m worried about what might surface next.
So what i’m looking for is recommendations.
-I have a turbo gasket kit with manifold, manifold-turbo, turbo-elbow, and both sides of intake, ordered and on the way.
-Want to replace all vacuum lines, but want to make sure i run them correctly, and not sure if they are correct now. They look like they have never been tampered with, but I found a website that says they are connected wrong. So which way is right? Will disconnecting the EGR and carbon canister effect my millage or anything?
-want to replace as many rubber fuel lines as i can just to be safe.
What do you think? anything else I should do? Any tips for what might help? I’m racking my brain trying to get this all figured out. It doesn’t seem like a leaking turbo gasket or removed EGR valve should have this much effect on my milage.
Thanks for reading, please help!!
