Cracks in frame
Hey guys i need some expert opinions here. I know its a stupid question but is it worth buying a '92 240 for less than a G if it has cracked in the frame or a cracked frame?
thanks
-Trey
what? 240s are unibody the whole thing is basically the frame–wheres the crack? and how big-if its not on a suspension mounting point and not big more than likely it can be welded. my front of my 240 where the toe hook is located was literally ripped-welded and now its fine. I assume you mean the rails on the bottom of the car that run from the front to rear more than likely you can just weld it
pics would be nice if u really want a true awnser to your question
