Well I discovered that my cruise control doesn’t work. I press the button to turn it on, but the light on the dash doesn’t even turn on. (I’ve had the car almost two years and I’ve only now tried to use CC, go figure.)
What things should I look at that may be causing the problem? I’m gonna check the fuse but what else should I check? If I don’t have the CC working it’s gonna be a loooooong trip to Seattle this August :lol:
lol TWO YEARS without checking it??? You’re welcome to pick at my parts car if theres a module or something that controls it that you think may be fried…
Look at the clutch pedal and you will see a small button that get puched in when the pedal is released, adjust it so the pedal presses the button down when the pedal is relesaed.
