I have a slight dilemma hoping some of you on here can help me out with. I need to purchase a dial style torque wrench and the smallest one from snap-on doesn’t go low enough for what i need to do.
The specs i need to measure are 7 in-lb to 29 in-lb… the smallest snap-on i can find ED1050 only goes from 10-50 in-lbs. FUCK.
Second I need a good dial indicator for measuring ring gear backlash with flexible stand. Theres a ton of them out there but i have no idea which one to buy and don’t want to get stuck with a dumper.
Starret indicator. nono on the flexible stand. get a quick release magnetic base with articulating arms. does little good if the stand moves on you while trying to take a reading.
torque wrench I have a digital snap on for the really low in-lbs readings. wasn’t cheap though.
