hi i am in the market for a VLSD diff, and have found a few , however there are from a non ABS car. The car i want to put the VLSD diff into has
ABS brakes.does anyone know if the ABS drive shatf and axles will bolt up to the Non ABS VLSD Diff? i dont want to buy the diff if its not going to work with my ABS brakes. lemme know thx.
you can easily search this.
ABS driveshafts are shorter… youll want to use a non-ABS driveshaft to have the proper length
conveniently, I have a non-ABS driveshaft for sale! $50 OBO =)
your abs wont work but as long as its a diff from the same chassis the axles will bolt up for sure,the driveshaft will be abit shorter but it should work.just grab the shaft from^^^
if you want your abs to work you will have to use a abs vlsd
If everything is North American then yes. There are 2 diffeent axle bolt patterns, but the 5 bolt ones were only sold in Japan (along with the 6 bolt ones).
But yeah, find the right drive shaft for sure.
And S13 will be different from S14 aswell.
u mean its longer
the neck of the abs diff is shorter. so the abs drive shaft is longer
but just buy mikes driveshaft
Actually Peter, Mike is right.
The ABS pumpkin has the sensor in it which makes it longer, and thus, requiring a shorter shaft.
the ABS diff is a few inches longer than the Non ABS diff
so the abs driveshaft is shorter in length vs non abs
what u need to get is a ABS driveshaft and ABS VLSD
i have an ABS driveshaft for sale
