Something i was just thinking about, i’ve always taken the engine out from above but if i have to replace the engine, engine cross member and all of the front suspension stuff anyway, would it be less work to just take it all out the bottom at once? S13 KADE
be pepared to replace the bolts that hold the x member in place. it has this weird plate holding the tops of the bolts in place so you don’t have to hold that end with a wrench when you take them out. there is a good chance the plate is rusted to shit. also the car will have to be pretty high to take the engine out. will the car be on a lift?
