My DVD-R drive decided it won’t read DVDs - It sits and spools up and down, but never loads them.
I’ve tried:
Pulling the jumper from “master” to “slave” and back, no avail
Putting in DVDs, DVD-Rs, DVD-RWs, etc, but no go
Putting in a “known good” drive - does the same deal
This seems like it has no software, only firmware? I downloaded what I think is the correct firmware but it didn’t seem to do anything.
What else can I try? I’ll get a model # when I get home, TIA :tup:
Mine wont read one disk for some odd reason. Shows it blank every time like its a black cd. All others work fine and the disk works fine on other comps.
TrueBlue, the quickest and easiest way to see if it’s a defective drive or software is to try and load a bootable cd/dvd. Whether you use the ultimate/hirens/multi boot cd, a live linux disc, or a windows install disc.
Next question is do cd’s work in the drive. if one works and not the other, it’s 99% of the time going to be a defective drive (like Paulo’s case) but does the drive show up in my computer, or if you go to device manager (right click on my computer, click manage, then choose device manager) is there a yellow warning over the cd drive?
