E-fans....
Hey, i have a few low profile e-fans that i want to wire into my s13 but i dont know what you guys are using to turn them on… i would prefer some way like oem to turn them on automatically with a manual override switch
for people that has done it before can you shed some light?
thanks
-Matt
you want to wire in a few fans? what’s wrong with one good one?
you need relay(s), a toggle switch, and possibly thermostatic switch… you can get thermisters as well which screw into the radiator like condensor fans use but unless you have a rad with the port and no a/c using it…
if you buy the stuff you’re looking at around 80 bux plus a day of wiring
did you search or check FAQ section? --rhetorical question as I already know the answer;
http://www.son240sx.ca/forum/viewtopic.php?t=17936
