Just did a hot rod etest, Results as follows …
ASM2525 test (40km/hr)
limit       reading
HC ppm 318 61
CO % 2.52 .04
NO ppm 3353 4390
RPM        2751
Dilution     14.24
at idle …
      limit       reading
HC ppm 300 71
CO % 1.50 .01
RPM        756
Dilution    11.01
Stock SR20, apexi fc, 10 psi, magnaflow high flow cat, 94 octane, runs wicked, no boost leaks or anything.
I m thinking maybe a new o2 sensor and run the test on stock ecu and i should pass? Etest guy was saying it looks like its running lean at speed. And it didn’t smell to good either. Not like that rotten egg smell without a cat, but like pollution smell.
Anyone know what i can do to make this thing pass?
