I have a sr swap. I am running my electric fan all the time. I want to know if there is any way i can run my fan with one of the temp sensors that are on the motor?
Please introduce yourself in the introduction section.
Most people who want to run the fan off temp sensors use a different sensor/switch system than the stock temp sensors.
Alot of highend electric fans come with a kit that includes everything you need.
I recommend you get a seperate sensor/switch system to run your fan from.
do you know of anyone who has used the stock temp sensor
OT: I STRONGLY suggest you re-register with a new screen name…too close to another former members…
^^^ That is true…
Tonys240 you the guy I met on Friday at Cayuga with the White S14?
BTW you cannont run it off the stock temp sensor.
Get an Adjustable one w/ temp probe from NAPA for like $20.
