Should I check the car first or somethin? I changed the clutch slave and everything runs smoother as if I just got the clutch replaced. The mileage meter is showing 112000km when its really about 180. Where is the O2 senser, maybe Ill check that one first and make sure if its still working.
Well I’ve done this everytime before my test and have never failed.
Buy a bottle of Octane Boost and Fuel Injector cleaner, put both in your tank FIRST, then add $10-$15 of Sunoco Ultra 94 gas. Now take your car for a good rip on the highway and stay high in the RPM’s all the time. Drive for about 20 min’s ish then just show up at any drive clean place and do your test.
Your doing this to help burn off excess carbon build up and with your engine up to optimal temp, O2 sensor’s warm, good fuel in the tank and clean injector’s you should pass ok.
Good luck man.
Easy 8)
