engine troubles..
ok i just finished workin on my motor.
and now if i start it let it run and turn it off and try to restart it. its flooded.
i am running with out an exhaust… so im wondering if that would cause the motor to flood like it is…
How long do you let it run?
My old NX2000 (sr20de) likes to flood if you just start it and stop it while it’s still in openloop mode.
ahh thats most likely the problem
im not letting it run to long.
Make sure you haven’t fouled your plugs, though if you’ve only done it a couple of times they are “probably” okay.
