Hey, I’ve got an SR20DET conversion done on my 240 that’s been trouble free for over a year now. Anyways, I’m having this weird problem where the car is making great power UNTIL 6000rpm where it falls on it’s face, Festiva style. I’m running both an analog and digital peak hold boost gauges and will see .95bar dead on to where it’s currently set and is not slow to get there either. But even just running off of the wastegate it’ll bog hard at 6.
I’ve tried tightening the spring on my blow off valve, re-gapping my plugs to .6 and done a complete boost leak test to 40psi with no leaks so I know I’m not losing it to a cracked intercooler or boost pipe. The clutch isn’t slipping as the rpm stays solid and I’m starting to run out of options. Idles great and pulls hard up to 6 so if you guys have any ideas to contribute I’d love to hear them. One other thing, I’m a bad donkey and am still running last years gas as I haven’t even burnt a tank yet (weak, I know) but can’t see this power loss at a specific rpm as a fuel related problem unless I’m way lean. I’m running a Walbro 255lph pump which are supposed to be good to 350hp and I’m nowhere near that so I’m guessing that’ll be ok.
Thanks in advance,
Kurt
