I try to open up firefox and it does nothing. I am double clicking on the icon on the desktop.I have uninstalled and reinstalled 2 times and it still willl not work. Any suggestions?
is it running in the task manager when u double click?
[quote=“SkunkApe,post:2,topic:29704"”]
[/quote]
no
Are you sure the process isn’t listed?
check processes…
Manually go through and delete everything having to do with firefox.
Registry, folders, etc.
delete and recreate your profile. I had a big thread on this a week ago or so.
YOU BROKE THE INTERNETS!!?!
If double clicking doesn’t work, run the exe from the run command and see if the program will start, if not. Delete everything, new profile, etc. Or maybe you broke the internets…
[quote=“ryanmcell,post:7,topic:29704"”]
[/quote]
You need to edit the environment variable to do that.
Not like its hard or anything, but it needs to be done.
so I started it in safe mode, closed it, reopened and it works fine now. IDK what that was about but it was not in processes or applications but it seems fine now. Thank you anyway!
