I have a nice set of cams sitting here I would like to install into my Crown Victoria for a little extra grunt, but I have questions.
MUST I remove the timing cover from the front of the engine?
or
IS there a way to temporarily hold the timing chain in place (without letting the tensioner push out), while I do the switch-a-roo?
Any tips, secrets, hints, etc are very welcome. Thanks a lot guys!
Justin
Dont need to remove the timing cover but it would make it easier. The timing chain tensioners won’t over extend. Lemme see if I can find a thread on svtp for ya.
http://www.moddedmustangs.com/forums/96-98/21676-cam-swap-sohc-4-6-1998-gt.html
looks like some ford tools are used to make not taking the timing cover off a lot easier.
There is a cam holding tool for this engine also.
I have a feeling I’ll be helping you with this…
Probably not, actually. I just found out that ALL 4.6L SOHC Camshafts whether it be Mustang, Pickup Truck, Crown Victoria, are all the same. This means the camshafts I have sitting here in the garage, are the same as what I have already in my car. Ugh.
Anybody wanna buy a set of PI cams?
fail
Can you send em out for a re grind?
