the speedo is all over the place, sometimes works, sometimes not.
does anyone have the voltages that the VSS should be sending out?
The temp gauge will start out at “C” then right as you turn on the car, it jumps to “H” even if you just turn on the battery and not the engine.
Does anyone know where the temp sensor is located and what voltages i should be seeing??
this sounds like a really common problem. on 95accordvtec’s car we had so many funky wiring issues like this it was unbeleivable. we tried replacing the cluster and that wasnt the problem. replaced the VSS and that took care of the speedo. replaced the thermostat and the coolant temp sensor and that took care of the temp gauge. the rpms and the reverse lights never coming on is another story.
