Getting out of drifting, will post up a full parts list soon. This car is for sale.
those that have seen it know that it has to ability to perform, I just don’t have the time for it anymore.  It still needs a little work and that is reflected in the price.
Car Basics
Fully built KAT - needs a tranny
Exedy twin plate
standalone megasquirt tuned to 7 psi
Engine can easily handle 20psi
14psi tune with a stage 2 clutch allowed for 300 wtq and 280whp, this just maxed out the clutch, u2dyno can tune you up to what ever you’d like
Corner balanced
Hydro e-brake
300zx brakes
T3/T4 turbo
CF doors
Car has no interior, no front signals, no horn, no cliamte stuff, no radio.
This car was built for the track, everything was taken out of it to allow for light weight.  Will put on 16" gold/black Advan’s with R comps on the front or 16" sparco with brand new rubber on the rear.  You’re choice.
$7500 obo
              This is what you get, I may be forgetting a few things, but here is the meat and potatoes
Engine
Weisco pistons
Pauter connecting rods
Ferria
- Valves
- Valve retainers
- Valve springs
Cometic headgasket
Toga high volume oil pump
Deutchwoks 740cc injectors
Exedy twin plate
Aluminum drive shaft
T3/T4 turbo
3” hot 2.5” cold IC pipes with t-bolt clamps
Bings large IC
IAP turbo manifold
48mm Turbosmart wastegate (7 psi spring, also comes with 14, 21 and one more just can’t think of it)
GReady Type S BOV
Bings exhaust
26mm 300zx brakes w. stainless conversion lines
Hydraulic e-brake w. stainless lines
5 lug
Walboro fuel pump
Bings short shifter
JDM GTR drivers seat for passenger
Knockoff Sparco seat for driver
Wideband 02
Zeitronics EGT sensor
CF doors
Fibreglass 180sx skirts
Bings lip
Momo steering wheel w. NRG quick release hub
D2 Coilovers (car is corner balanced with me @ 160lbs in drivers seat)
Extras I’ll throw in
2 hoods - 1 red clean, 1 champagne salvaged from bad vent attempt.
Tires - what I’ve got, I gotta get rid of enough for almost a season of drifting 17” and 16”
3L transmission fluid
Can deliver anywhere between St. Catharines and Ottawa upon payment.
              Bump
Some things I forgot to add:
Solid aluminum subframe bushings
Bings multi link
Test pipe
NRG 4 point harness
Advan have (F)2x Advan R-comp ®2x RE-01 (decent tread left on all)
Sparco have (F)2x spent ®2x Falken Zeix912 (new)
225/50/16 on all the above, spare tires vary, but in that range.
Free spare open diff.
Will also do a package deal
Car and new open car hauler (2000km at most) $10,000
PM for trailer details if interested in package, will not sell trailer before car.
