my fuel is leaking from my car as if it were a siv!
does anyone know a decent shop to install them (fuel lines aquired so no need to worry bout that)
its too easy to do yourself if u dont mind getting a bit messy. If your Reallly lazy you could just get 12 feet or so of rubber hose and run it from your fuel sending unit to the fuel filter in the engine bay. <—I have never done that and belive its a 1/2 ass way of doing things but i see it working well…until you bottom out or somehow pinch the rubber line.
see thats just it, im kinda tools limited heh…
Running rubber hose any more them like 1’ is dum. A shop will not charge you that much just to fix a lil fuel leak. All they do is just cut a section out of the fuel line where it is leaking, and just put a rubber hose on it with 2 hose clamps. It takes not even 10 min if it easy to get to.
