How it works:
Higher octane = resists pre detonation (aka harder to ignite)
Basically you should run the lowest octane that doesn’t cause knocking in your engine.
If you are bone stock you should run 87 (for a KA … don’t ask me about sr)
Advanced timing, cams, higher compression, turbo, etc etc = you’ll likely need/want a higher octane to prevent detonation.
But the point i’m trying to get across is that if you are not having problems with detonation buying more expensive fuel is just flushing your money down the toilet.
I run Petro Canada 91 every time not matter the price, I get a
min of 40+km to the tank using 91 as apose to 87. KA’s were
designed for 91 Octane. They automajically retard timing when
running under 91 octane hindering preformance and milage.
i hope everyone using 90+ octane is running some sort of forced induction, high compression or has a really old motor that knocks otherwise like someone said in previous post, waste of money.
Mr Jantos claims the motor backs off timing if you put lower octane but I didn’t think it was that advanced.
The way I understand it the engine runs normally … then if the knock sensor decides the engine is pinging then it severly retards the timing. Not butter.
