Great read on proper oil selection for turbochargers..
http://store.forcedperformance.net/merchant2/graphics/subaru_oil/Forced%20Performance%20Recommendations%20for%20Motor%20Oil.pdf
It’s rare that you’ll find real world testing like this. Good stuff!
Very good read and thanks for posting.
I’d be curious to see what our members are using in their engines and both the positive and negative results of the products they use.
You’ll be hard pressed to find an engine problem/failure directly related to engine oil. Of course, everyone will ‘defend’ their brand of choice. I use Valvoline VR1 20W50 conventional. Why? Read the article, plus it’s readily available@4.50 a quart (no shipping charges etc).
I’m using Mobil 1 because that’s what the manufacturer recommends plus my Evo is very lightly modded.
Great read! Mobil 1 for my s4 over here
The manufacturer recommending that is just all a marketing deal between the two manufactures. If it were mine, I’d have one of the oils that FP suggested in it. No need for a heavier weight though (VR1 10W30 would be my choice).
Thanks Travis I’m going to give it a try for my next oil change. :tbu
No problem. They also make it in a synthetic, but no reason to use a synthetic unless you’re going for extended drain intervals.
From reading a few articles about this product on EvoM I’ll probably go synthetic, plus there’s a pretty good rebate on a case good through 9/30/11. http://www.valvolinevr1racingoil.com/
You can’t go wrong either way. Take advantage of the rebate!
mobil 1 is prolly the worstttt of the synthetics out there
Your Cenpeco would also make the list of great oils.
What makes you say that?
It’s just as good as any other SM/N rated (30 or under weight) oil. Just has reduced antiwear additives to meet ILSAC GL-4 specs (SFI thinks that increased antiwear additives hurts cat converters…BS)
we had our b-g rep come in with one of those timkin bearing testers that ya see on the late night infomercials . we tested a bunch of the popular oils and such . mobil 1 was worse than our drum conventional in all areas . the best conventional was the valvoline and cenpeco right along with the walmart supertech lol
Mobil1 20w-50 Vtwin looks like a winner.
Damn. Thanks for the info.
Walmart oil does amazingly well… we used to send in our oil for analysis and it always was near the top.
he doesn’t NEED to change in all honesty, he still has the stock turbo which has the brass bearings unlike the FP turbos which have steel bearings.
Sure, but increased anti-wear additives are good for the entire engine IMO-not just certain turbo bearings.
