I have 97 acura GSR i am having wiring problems. The car has a wire tuck and for some reason one tail works but the running light work fine and i also have no high beam. Does anyone have an idea where to start with this issue? When it comes to wiring i am lost.
get a wiring diagram, check fuses, and get a volt meter and start checking powers and grounds per diagram.
Or hire Lksi :ponder
wiring sucksssssss. worst part of a car imo
Checked voltage at all the plugs get voltage for the tail lights but the high beamms getting nothing check the fuse, fuse are good but no voltage to the fuse box but the switch still works cuz the light on the dash turns on
LKSI?
Name of a member.
SO come to find out that there was some wires that were spliced cuz it had an aftermarket alarm now i have figure out why the reverse light arent working
