Well, last week I decided to take a look at my airbox to see if I could modify it in any way, and before I knew it, I had the whole silencer box out and the pipes to it capped off.
I filled up just after that and am now at a 1/2 tank and only drove 180k’s! Normally I’m sitting at about 300k’s after a 1/2 tank.
Is it that the MAF sensor is picking up more air flow and dumping in more fuel? The thing is though, the car doesn’t really run and different, other than being slightly louder in the upper RPM’s.
yea i did the same thing initially, chopped the bottom off, went for a drive and it sounded so much better i couldnt help it and drove the snot out of it. I grew out of it in a tank or two.
ya I have the same thing done to mine and I flogged it a couple times you would be surprised at how much gas you can use by just a few short drives at higher rpm.
180 km’s for 1/2 tank sounds about right I have never gotten more then 380 to 400 km’s to a full tank with my car. Once you start doing modifications don’t expect to keep getting good gas mileage it doesn’t work that way. The more mod’s the more gas you will burn.
180 km’s for 1/2 tank sounds about right I have never gotten more then 380 to 400 km’s to a full tank with my car. Once you start doing modifications don’t expect to keep getting good gas mileage it doesn’t work that way. The more mod’s the more gas you will burn.[/quote]
the hacked airbox is the only mod he has judging by his sig, and i have hacked airbox and catback, and i get 550-600 km a tank
