calling out all the ppl i know and dont know
i really want to make it to track this saterday 10/09/10 but the stud close to the front of the car snapped(runner one). i need help asap to remove this stud out of the KA24DE at my garage (dvp/donmills). also if you have experience i need help T’ing vacuum for wastegate and bov from 95 ka24de.
please call or text me at 647-405-3513 or msg here to save my car.
Depends how it’s broken. Can you grab the broken part?
Or is it broken INSIDE the manifold?
You may have to Drill it out… That is a HUGE pain. Suggest a 90 Degree air drill.
Depending on how bad, it should either be retapped, or T-Sert’d
If there is enough to grab it with vice grips, you may be able to twist it off but that usually requires taking off the whole manifold/turbo assembly to do it properly.
