HELP! clutch problems.
I tried searching and couldnt find anything. The symptoms are as followed.
Fluid is topped up
Clutch slave is moving
Clutch point is normal
clutch engages and dis-engages as normal but when engaged the car does not move. Im a little stummed on this one. Any advice?
Cliffs: clutch is same as always, car wont move
blown diff or tranny?
i broke an axle (cv joint actually) once and because it was open diff the car wouldnt move
this was on fwd but same idea
when u try to drive does your speedo say your moving at all?? if it does id say u got an open diff and its popped… but u woulda heard that blow up… does the drive shaft spin?
more info.
