I was cruising with 87fox and testicle around fox’s yard maybe 15-20mph and while i was driving it just shut down and came to a stop. i then tried to start it and it makes a weird grinding noise. but the cord is still hard to pull and chugs so there still has to be compression? im thinking its something to do with the crank?
crank bearing isnt going to cause the compression numbers. time to pull the jug and rebuild it. two strokes are super easy and pretty cheap to rebuild.
did you have enough oil in it? my first guess on the weird grinding noises would be crank bearings, most likely getting chewed up and spitting shrapnel up the transfer port and probably breaking a ring.
yeahh i pulled the head off of it and i see that there is some weird scratches on the edge of the piston and also has same scratches on the head in the same spot.
where is the noise comming from? My buddy had a similer problem with his 670 mxz and it ened up being the stator. It basialy fell apart and was jumping around inside the flywheel. See if you still have spark and fuel then go from there.
