the window rolls down fine, but it doesnt roll back up, at all. doesnt even try. Just the drivers side, the switch or something was already replaced by the dealer
is it the motor/regulator? or a relay or something… idk much about this stuff
well with mine when it was the regulator, to get it back up, all i had to do was pull up on the glass while hitting the switch and it would come back up. so try that maybe it will work. not making any promises here tho.
but mickdad makes a good point as well the motor could be burning up.
i got the whole door panel off, except for the top part, i didnt want to break anything so i just popped it back on
so if i bought a new motor/regulator would that fix the problem?
im pretty sure if there was a little bit of window showing, we could grab it and it would then be able to roll up on it’s own with a little man-power help
