Help with 2001 1.8t Jetta.... again
sorry i did not read that part, but did i not recommend upgrading the downpipe?
anyway browse around it seems that after 2002 they seem to be more reliable. and the vr6 is much more un reliable than the 1.8t just saying…
You also recommended just pulling the sensors.
Just stop posting in here. You don’t know what you are talking about.
Have you hooked this car up to a VAG COM and ran the codes? The MK4’s are notorious for needing converters, it’s not if that converter is going to go, but when the converter fails. My GF’s 01 Jetta needed a converter at 100K miles, WTF car needs a converter at 100K? But the car ran fine, it just threw the fucking code fucking it up around inspection time. This liquid on the tips, does it look like thin frothy chocolate milk?
That sound would be your throttle body closing.
Depends on the tune. I know that apr’s tune is a simple cat delete nothing else. So that wouldn’t be the issue if it was apr. Uni and giacs a different story.
This would be my guess if i didn’t have the car in front of me. Live around lancaster??
so put the 3inch back on problem solved?
I can drive out there.
Look, I’m asking for advice to fix this thing, I’m frustrated, annoyed, pissed off. I don’t got a shit ton of money so I went the less expensive route. Turns out it fucked me.
I am scanning it again tomorrow. Gunna try un hooking the maf and switching the packs around. If that does not solve it, I will look into other options.
School me on going catless and what kinda tune id have to get including cost as that is my major opponent in this.
The 3" downpipes flex pipe was completly blown out.
Well I’m under the impression that you have software currently on your car? APR? Uni? what company. If you changed the packs and plugs your fine. Ignition module would be my next bet, cleaning the maf wouldn’t be a bad idea just get some maf cleaner from a parts store. If you bring in the ignition module into an advance auto parts they can test it(assuming the guy knows the right connections).
I’m not sure on the software as I had bought it with the tune on it. Said it was done by blackforest…
blackforest is a giac tuner so if its the tune he can fix that and he should do it for free. I’m not sure the file is just a delete of the cat or if it is a tweek of the timing/fueling. I’m pretty sure its not the software though.
Okay well I will get ahold of dale over there to check shit out… thanks
