i know i wrote that wrong…but i’m havin the funnest time trying to figure out where this line leads to…its the piece that comes off the valve cover (on usdm passenger side) and goes straight down. i’ve been trying to find where it leads to from all sorts of angles but keep losing it. i basically need to know because in the midst of removing the valve covers i put a huge hole in the line and need to replace it.
when looking at the valve covers it is the piece that is unpainted
the piece that i demolished and how it goes onto the valve cover:
where the other end of the rubber piece goes into:
so basically just need to know what flows through there so i know what type of line to replace it with
I believe there are few different kinds of set-ups on nicoclub forums that includes using/eliminating both breather lines on the valve cover… check out the forums.
