HICAS LEAK!!
hey guys i gotta MASSIVE power steering leak in front of the right rear suspension where the power steering line bends up, wat is the best fix, i don’t really care for hicas cause it’s pretty gay,
I’ve had the car for while now and been with son 240 for a while but haven’t been able to post anything cause i didn’t really know how
neways i would really appreaite thanks!
Is the line itself leaking? If so, you’re best off replacing the entire line. No use doing quick fixes over and over again only to have them fail and start leaking again.
yes if you are going to fix it, replace the entire line front to back.
or you can eliminate it with our rear lock rods, and a non hicas pump.
there is a connecter somewere at the rear where it branchs the 2 lines off it, ive heard u can make it a closed loop… like disconnect one aan move the other one to close the loop
{}= (the spliter with the 2 lines)
{}) (use one of the lines to connect the 2 holes… dont know if it makes sense…)
just heard about it once for disabling HICAS…
