Car won’t stay on. Start - high idle (1400 RPM). 5 seconds, and then it dies. No throttle response. Thinking, needs vacuum.
There’s no N75 valve, it’s on a MBC and the software is supposedly tuned to not care about it.
Ideas? Besides : I think you have a bad ground.
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Control Module Part Number: 8E0 909 518 AK HW: 8E0 909 01ÿ ÿÿ
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 0016711
Work Shop Code: WSC 00000 000 393216
VCID: 79F21DBF49B1
4 Faults Found:
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 002 - Lower Limit Exceeded - MIL ON
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 002 - Lower Limit Exceeded - MIL ON
17881 - EVAP Leak Detection Pump: Open Circuit
P1473 - 004 - No Signal/Communication - MIL ON
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 002 - Lower Limit Exceeded
