honda cable trans help needed
my honda is a crx si 1990 with a cable tranny.
it’s having a lot of trouble getting into gears and I’m pretty sure it’s cable related.
the clutch is fine because it has plenty of pressure.
it doesn’t grind going into gear… it just sort of refuses until you really crank on it then it will pop in. gears 1,2,reverse go in pretty easy (but not prefect). 4th and 5th are really hard to get into gear.
I know what bad syncros are and this is not that.
thoughts?
is this just an adjustment?
if so how?
thank you.
id check and make sure you have the proper amount of lube.
change your fluids and check for any kinda binding of the shift linkage and also if you have a short throw shifter make sure the counter weight isnt hiting the exhaust or anything.
sounds to me like a bent shift fork or possible changer. all of wich are internal.
