well when you return home if you are still stumped on it, get at me i’ll try and assist you.
sure thing. Ill probably take you up on that offer.
when you tried messing with the timing, were you using the jumper or simply adjusting the distributor?
adjusting the dizzy
Im not sure if its the same or not, but on my teg, I had to use the jumper to adjust the timing from the distributor, because the ecu would just compensate and keep the timing messed up
Im not familiar with that. Do have a how-to link or something?
i found a basic thing about it. I wonder if it does anything for me since i havnt had a battery in the car for a year… Ill try it regaurdless.
heres a write up with pictures, Im pretty sure its the same for D series
