There is another way to increase boost on the stock wastegate.  This is what I ran accross by accident, and I make no guarentees that it will work for everyones car…buuut it did raise my boost from stock of 8psi to 12.5 PSI!!! That is right…12.5 PSI
Anyway, this is what I did, and I cannot post pics as of yet, cause I dont have a web address but here it goes it is pretty simple.
There should be a vac line that runs directly to your wastegate.  (Correct me if I am wrong on this one) but that line runs from just before the throttle body and monitors the amount of PSI running to the intake.  At stock boost of 7 or so psi (depending on BPU) the wastegate will read 7psi and open up, thus stopping anymore boost pressure.
What I did was connect the line that is running to the wastegate to a T-offconnector.  So picture the line running from before the intake to the T-off connector, then one side of the T-off connector going to NOTHING (OPEN AIR) and the other side connected to a line going to the wastegate.  This gave me 12.5 PSI of boost, solid all the way to redline in every gear.
Again anyone may feel free to correct me if I am wrong but this is the explanation of what I THINK happens to increase boost pressure.
First I will basically explain what the wastegate does (in essence).  It controls the exhaust air flowing around the turbine by use of a pressurized (air/spring) combo.  At a certain air pressure the wastegate will open and let out a certain amount of exhaust gases (into your exhaust system, or downpipe).  At this point, (where the wastegate opens) you will get no more boost.
Ok so with that being said…
The wastegate is supposed to be getting a 7PSI reading from the cold pipe (through the vac line), however if you let some of the air that is flowing through the vac line to the wastegate out, it will get a lower pressure than is actually being created.  This will keep your wastegate closed for a longer time and thus enable you to build more boost.  Again, the wastegate is supposed to be getting a reading from the cold pipe vac line, HOWEVER you can “let off” some of the air at a T-off connector, thereby reducing the supposed 7PSI in the vac line to something lower, like for eg. 4PSI.  Thus the wastegate does not think it has reached 7PSI, and lets you build another 3PSI of boost.  Because the air is moving at a high pressurized speed through the vac line, there should be a point at which there is enough air (even with some being blown off) to get a 7PSI reading to the wastegate.  It is at this “fake” 7PSI setting that the wastegate opens and your max boost is reached.  HOWEVER the fake 7PSI reading is ACTUALLY 12.5PSI with 5.5PSI being blown off at the T-off connector!  THAT is how this $2 mod should work.
My warnings are this.  I have BPU mods on an SR, I was using a long ass vac line (worse spool up time) and a Y connector for this mod.  My boost was 12.5 PSI (on 2 boost gauges) for a few days, until I decided to change some stuff.  I HAVE NO IDEA HOW THIS WILL REACT WITH YOUR CAR.  I HAVE NO IDEA HOW MUCH BOOST YOU WILL GET FROM THIS.  Read my explanation of how it builds pressure over and over until you feel safe doing this mod, or until you find something seriously wrong with it and if you DO find something seriously wrong then let me know so I dont blow up my engine or something.  IT SHOULD WORK for at LEAST A FEW MORE PSI THAN STOCK, and I know it worked for me.  In theory it makes sense to me, but maybe not to you.  Do what you will, it is your car, experiment, and have fun, but I take NO responsibility for what happens to your car.
BTW 12.5psi is damn fast.
l8ts…
