How to test tweeters
Ok i have a set of tweeters and one of them work fine but there is no sound coming out of the other one. Is there any way for me to test them. thanks
you can always try to touch both wire leads with a small power source like a 9 volt battey and see if you hear anything. if it pops then you at leasr know there is still a connection. and just use a volt meter taht can read ohms and see what it tells ya, if it is not reading around what the speaker is rated at (probbley 4 ohm) then you have a short in the coil.
well there’s a couple ways to test but i usually just jump some audio source to one, you could use the wires from your car stereo and touch them directly to the terminals on the tweater and listen for sound or like me use some sort of hacked up headphone cable and a walkman and touch those wires direct to the terminals and listen for sound, using this method u’d be surpised how many things can be adiqutely powerd by a walkman…lol
