creepy gay mechanics itt
Are you really going to argue a $3.00 difference from 2 different places? It blows my mind sometimes how much of a big deal people make over a couple of dollars.
No im not arguing the price between two places…i just cant believe a needle and seat is 40$$…i can get a whole rebuild kit for that
then get the whole rebuild kit …might as well have the carb working its best
:ponder
Hanks the man…every need help with your quad i recomend him
your welcome man any time!!! now get that cable straightend out b4 u end up in the brush… :eek
on a side note.
the ethanol usually dont break down enough (debating on sit time.) but rather corrodes the needle in the bore .
if i had to take a guess i would say it was the ethanol reacting to the aluminum , and seeing how the tolerence r real tight it dont take much for it to stick…
but never really know how bad the inside of a carb is till u crack it open… :ohnoes
Cable is fixed and so is the idle…were going out at like 430-5 tomarrow if you wanna come??
ya maybe. maybe i’ll blow the cob webs out of the yammi…
well i was out riding today when the top end starting to tick really bad…i think i need to do the valves :ahh
UPDATE…i took the valve cover off today and found the screw that holds the valve inplace was backed all the way off…bad new is i couldnt find the nut that holds it on :ohnoes…its going to hanks today ASAP
